Headlights..........
Old 03-16-2008, 10:06 AM
t0n33's Avatar
good afternoon fellas...........as you may know westcoast customs did an hhr build and if you havent seen it yetr they have a smoked headlight and tailights anyone know how to do this....................
t0n33 is offline
Old 03-16-2008, 10:29 AM
saltyfishguy's Avatar
I have used window film to do it before, a few times, worked good. Looked
saltyfishguy is offline
Old 03-16-2008, 10:34 AM
Mine was done professionally with a spray:
There is a product called NightShades that you could use to do the same thing yourself.
HillsdaleHHR is offline
Old 03-16-2008, 02:29 PM
1Panel2NV's Avatar
You can get precut vinyl overlays for the headlights here. I also got a blue sheet for my fog lights, though you can't see it in the picture. Like HillsdaleHHR said, I'd recommend a spray for the tail lights because they are so curvy. Whether it's done at a shop or with nite shades, which you can find on ebay.
1Panel2NV is offline
Old 03-16-2008, 03:53 PM
I had the overlays on my headlights for a while. Liked the look, but not the reduced light at night. Took them off after a few weeks.
GDZHHR is offline
Old 03-16-2008, 06:21 PM
stick's Avatar
I just ordered a set of headlight covers, forgot you even had yours. How hard were they to put on? Did you have to use a soap solution or anything?
Last edited by HillsdaleHHR; 03-16-2008 at 07:05 PM. Reason: Removed pic from quote
stick is offline
Old 03-16-2008, 06:51 PM
BigMOCats's Avatar
Easy to put on but I lost one after a couple of weeks. Just blew off one night cruising, I wasn't even on the highway.
BigMOCats is offline
Old 03-16-2008, 08:33 PM
1Panel2NV's Avatar
I used a solution from their site. There is plenty leftover if you want to use it. I got the thick protective vinyl, not sure what anybody else had. Mine have been on through an Illinois winter and I haven't had problems with peeling or anything. I didn't notice a difference in visibility at night either. The install was a little frustrating, but it might have been the thickness of the vinyl or because it was cold when I put it on, or lack of vinyl experience. Ended up with quite a few bubbles, but they all went away after a couple weeks.
Old 03-16-2008, 08:44 PM
ymerej_mortsdnil's Avatar
Question
where did you purchase the set for your fog lights?!?
Last edited by HillsdaleHHR; 03-16-2008 at 09:05 PM. Reason: Removed picture from quote
ymerej_mortsdnil is offline
Old 03-16-2008, 09:06 PM
1Panel2NV's Avatar
Same place. You have to buy a sheet and cut it to size.
Quick Reply: Headlights..........
