how to pull headliner to replace antenna base
I would think that you need to pull off the A-pillers and side ones. Then the roof light and switches. It should come down after that. If you need more room you'll need to take off the rear light. This is how I would say it comes off.
Remember we need pics of what your doing.LOL
If you unbolt the sunvisors the headliner comes down and towards you out of small retainer clips similar to the plastic cover in the center of the weathertripping in the back hatch that you have to remove to get full access to the battery. You can pull it down far enough to access the antenna and LED light (or sunroof controls if you have them) without completely removing it.
Thanks SYE!
TAK
0
05-10-2012 07:53 PM
