Issue with IPCW LED - Running Light Not Working
Old 06-17-2008 | 05:48 PM
Thetaxi's Avatar
Ok so I installed the LED tail-lights however the running / parking light function is not working. i.e. The tail-lights only light up in reverse, braking, turn signal.
Anyone else have this problem? Did I get the wires crossed?
Edit: Just checked the front parking lights and they don't turn on either.
Old 06-17-2008 | 06:30 PM
Thetaxi's Avatar
I'm blowing the 10amp fuse so I'll put the stock lights back in and see if they work.
Old 06-17-2008 | 06:42 PM
FlaHHROwner's Avatar
also make sure you did not pinch any wires while installing the new lights
Old 06-17-2008 | 07:11 PM
shaginwgn's Avatar
better check your wires/ground because you are pulling too much of a draw.
Old 06-17-2008 | 07:17 PM
SLVR FOX's Avatar
mine did the same. i pulled the "bulb" and flipped it around and it worked.
hkoehler459
06-11-2015 04:54 PM
wagoneer
02-19-2009 06:56 PM
itschaboykenny
02-17-2008 01:01 AM
BamaHHR
07-09-2006 03:56 PM
