LED brake light bulbs
I did a search and could not find the answer to my question.Does anyone make a LED bulb that has the required ballast built in? And does our HHR have the required electronic turn signal switch so the LED bulb will function properly?Thanks in advance for any input on this,HB
yea you can buy jus the bulb but you have to use the ballasts no matter what kind of led bulb you use, the have some at a parts store down here in ohio, they arent the spider lites though they have like 9 bulbs on them. The reason you have to put the ballasts on is because leds are low voltage and when our HHR detects low voltage it thinks the light is out so it blinks crazy fast. No you dont need to do anything with the signal flasher.
I am going to try and get the 3057 and 3157 replacement bulbs for the front and rear turn signals I hope.The site I listed has the 3157 for the front but does not list the 3057 for the rear.I guess I'll keep searching.I just like the idea of a brighter light and faster on and off that the LEDs provide.I am also thinking of getting one of those electronic third brake light flashers as well.I have seen one of those in action and it really gets your attention when you see it. http://www.ecklers.com/product.asp?p...6&dept_id=1384 Found some more on this site as well:http://autolumination.com/3157_3156.htm
I purchased the 3157 wedge Matrix II dual circuit (32 LED in red) and 6 ohm load equalizers to fix the fast flashing problem. You can find both at autolumination.com.
http://www.autolumination.com/
