LED brake light bulbs
Old 03-18-2007, 09:10 PM
HHR PNOY's Avatar
sorry...had them on before but I recently sold the HHR and never bothered taking pics of the tail lights.
HHR PNOY is offline
Old 03-09-2012, 10:20 PM
phcoy's Avatar
LED Lights Hyperflashing
I had the fast "hyper" flashing problem after installing led bulbs in my HHR tail/stoplights. But only when the headlights were fully on, such as at night. The LED bulbs just didn't work out for me, unless you like the "hyperflash". Modification will be necessary to make these work. No plug and go.
There are allegedly electronic LED flasher control units available that are supposed to fix this problem (www.superbrightleds.com). The only problem is, you need to know the OEM flasher's base mounting pin orientation to get the correct replacement unit. Since I haven't been able to determine where the OEM flasher is in the fuse box mess (the owner's manual is no help), and pull it out to look at it, I haven't been able to order a replacement electronic version. So, I'm just limping along with the original tail light bulbs.
phcoy is offline
Old 03-10-2012, 08:32 AM
atom's Avatar
http://www.bigmotors.by/forum/viewto...t=108&start=60
video
http://www.youtube.com/watch?v=osNNl...layer_embedded
http://www.youtube.com/watch?v=PM37Q...layer_embedded
atom is offline
Old 03-10-2012, 12:34 PM
Joshua022's Avatar
Nice, if only I could read it..lol
At least we know it's possible
Joshua022 is offline
Old 03-11-2012, 01:47 AM
jeff schaffer's Avatar
Used them... autoilumination
I just did my dome lite ect... with them love it!
pics soon....
jeff
jeff schaffer is offline
Old 03-11-2012, 08:08 AM
prod's Avatar
Originally Posted by phcoy
I had the fast "hyper" flashing problem after installing led bulbs in my HHR tail/stoplights. But only when the headlights were fully on, such as at night. The LED bulbs just didn't work out for me, unless you like the "hyperflash". Modification will be necessary to make these work. No plug and go..
Did you use the load resistors?
prod is offline
Old 04-03-2012, 04:09 AM
I dont know the stereo shop I work with did all the work, but they work & look great no problems low cost upgrade.
jeff
Old 04-06-2012, 01:09 PM
hhrumadbruh's Avatar
I believe the term you need to research is canbus
I just left the turn signal faster and un plugged the chime.
hhrumadbruh is offline
DLVRNIT
Maintenance and Upkeep
10-05-2023 02:22 PM
bigboss2010
7
06-26-2012 11:10 PM
hhr-mn
14
04-07-2011 03:14 PM
solman98
01-07-2009 06:24 AM
patrick49
08-15-2008 08:27 PM
Quick Reply: LED brake light bulbs
