Mud Flap installation
I thought I had found in the past about mud flap installation tips! But the "SEARCH" feature isn't working! Can someone help me! I thought I'd seen something about the mud flaps scuffing paint and someone mentioned about putting 2-sided tape on before installing?
Thanks in Advance!!
Sincerely,
Jeff Wysocki
Brownstown Twp., Michigan
Summit White 2006 LT
Thanks in Advance!!
Sincerely,
Jeff Wysocki
DARK AGE 53 had instructions here: https://www.chevyhhr.net/forums/show...=splash+guards
Once I got my splash guards I tried the 3M double sided tape, the 3M tape has protected the paint. I did not use the front fender metal clips that come with with the splash guards, I felt these might cause a rust problem someday...I bought some new plastic push pins and used them instead. BTW, being the rear fascia won't rust I did use the metal clips there.
Jeff, I have a lift and if you live anywhere near DeWitt you're welcome to come on over and we'll get them on for you.
