New Audi Style Lights...
Old 01-18-2011, 09:59 AM
  #41
Originally Posted by whopper
If you are doing projects such as these, you would be well advised to invest in an inexpensive multimeter. http://en.wikipedia.org/wiki/Multimeter
They are easy to use and it will save you a lot of time, and will pay for itself many times over. Even if someone here posted the correct answer, I would still double check with a multimeter myself.
Multimeters are handy for checking light bulbs and various bulb sockets, as well as tracing wiring faults, and presence of voltages, as well as checking grounding.
What he said,when I was installing leds on the BMW wires were clearly marked but some how some one got the polarity switched on a fog until I tested it they were a no show leds won't go when the polarity is wrong. so even a continuity tester will do it for you that's how I found the marker hot side. and its easier to figure out than a multi meter
SS fan is offline
Old 01-20-2011, 06:13 PM
  #42
Double0's Avatar
Check mine out.
6000K HID Custom projectors LED Angel eyes and LED blinkers
Double0 is offline
Old 01-20-2011, 06:16 PM
  #43
Awesome Dude,You and Lunchbox do nice work absolutely
SS fan is offline
Old 01-24-2011, 08:12 PM
  #44
BlkSilveradoSS03's Avatar
you can also get a product from ideal at lowes called No Locks- it's used i nthe electrical industry to prevent corrosion on aluminum feeder wires, works great as an anti_seize compound as well.
BlkSilveradoSS03 is offline
Old 01-24-2011, 08:16 PM
  #45
THE BATMAN's Avatar
Originally Posted by Double0
Check mine out.
Looks like the eyeball of a dragon !
THE BATMAN is offline
Old 01-26-2011, 08:27 AM
  #46
daddy2isaiah04's Avatar
Electrical problems...
Well, just so everyone knows. I did you use something like scotchlocks to wire these lights on my car. I have now been driving in crappy Ohio weather for quite a few months and have had no problems at all with the lights failing or shorting out, and we have had snow frequently over the past month. Just thought I would let everyone know.
daddy2isaiah04 is offline
Old 01-14-2012, 01:17 PM
  #47
JTKrupa's Avatar
What about 2 strips?
What about adding a second strip offset a little from the first? I realize the spacing is super tight, but you could potentially remove the lights and maybe dremel a little off the bottom to make a hair more room for the doubled strips...the you would have the "twice as many" look...either that or just really wedge them in there after using the adhesive from one of the strips to stick them together.
Personally I think that is the way I'm going to go since I need to hit up Wally world today anyway. Since I already have the ddm hid bulbs in 55w 6000k, these will match up nicely, both the strips and the headlights super white!
Will be sure to post pics in a thread of my own maybe when I'm done...
JTKrupa is offline
Old 02-19-2012, 05:32 PM
  #48
two strips offset will fit.
SS fan is offline
Old 02-19-2012, 05:50 PM
  #49
bigjacksauto's Avatar
Very cool mod
What is the name brand and in what aisle in Walmart
I am assuming that they are 17 dollars for the set
I. Also assuming you need a positive and negative feed?
Where are you grounding to
bigjacksauto is offline
bartSS
03-16-2011 03:49 PM
THE BATMAN
Racing Discussion
10-15-2010 09:22 PM
StormChaser
26
07-19-2008 09:33 AM
HillsdaleHHR
02-08-2007 09:05 PM
Quick Reply: New Audi Style Lights...
