New Wheels -- Boyds Smoothie II's
Old 07-14-2006 | 09:00 PM
Markiemark's Avatar
Thought you might enjoy my evolution of a Modern Street Rod ----
Orginal (Sort of) Whoa!!! looks like a 4 Wheel Drive
Better Stance: (Goldlines)
Upgraded Wheels: Boyd Coddington Smoothie II
Wheel Close-up:
Hot Licks:Custom Tint
Enjoy!!!!
Old 07-14-2006 | 09:03 PM
Novadiecast's Avatar
Those are awsome!!!!!!!!!!!!! I didn't care for the low stance ....until now!!!!! What size are the wheels and tires?
Old 07-14-2006 | 09:12 PM
Songman's Avatar
Looks good... I saw some things the other day that go behind your wheels to cover up the drum brake and makes it look like big drilled rotors. They would look good on this big wheels.
Old 07-14-2006 | 09:22 PM
HHR PNOY's Avatar
do you remember where you saw that from songman?
Old 07-14-2006 | 09:55 PM
Markiemark's Avatar
I plan to check into them, they can be seen at:
http://www.newstalgiawheel.com/listp...s.asp?cat=5041
It is a cover that goes behind wheel, just need to check on if they work with the drum & disc setup?
Reading description, says designed for rear wheel drive only, bummer!!
Old 07-14-2006 | 09:59 PM
Markiemark's Avatar
Thank you!!!
Size is 17" x 7.5", same size as the Chevy 17" wheel.
Offset is a tab bit different, not much, but some.
Old 07-14-2006 | 10:08 PM
TruckSHOP.com's Avatar
Former Sponsor
Well, they don't make a 7.5-inch width, it's either a 7 or an 8. If you put the stock 215 tires on them (and they don't look stretched) then they are a 17x7. Factory wheels 17x6.5
As far as the polished wheel discs, they won't work in front. The disc needs to sit flat on the hub surface, so it would hit the brake caliper. You could put them on the drum brakes in back.
The wheels certainly do make it look a lot more retro.
Old 07-14-2006 | 11:42 PM
HHR PNOY's Avatar
puting the accents on the rear only wouldnt look so bad. It might even make the rear rims/tires look bigger.
Old 07-15-2006 | 07:10 AM
oldschoolfreak's Avatar
they look good markie!!!!!
Old 07-15-2006 | 07:17 AM
EZ4U2CHere's Avatar
Looks great!!! Doesn't even look like the same car!
Quick Reply: New Wheels -- Boyds Smoothie II's
