Pinstripe from Manufactorer??
Chevy is now adding pinstripe directly from the plant... (checked chevrolet.com, and click build, 08 HHR and type in your zip) it's towards the bottom of the build page... wonder if this is going to be a painted pinstripe or vinyl
That's what this refers to:
Week of 12/10/2007
Effective 12/10/2007, the following changes will be made to the Vehicle Order Guide:
• Color and Trim section-Added (17A) Single Smoke Accent Stripe. It is available with all exterior colors except (37U)
Imperial Blue Metallic and (75U) Dark Gray Metallic.
• Color and Trim section-Added (96A) Single Silver Accent Stripe. It is available with all exterior colors except (15U)
Sandstone Metallic and (67U) Silverstone Metallic.
• Color and Trim section-Added (47A) Double Smoke/Smoke Accent Stripe. It is available with all exterior colors except
(37U) Imperial Blue Metallic and (75U) Dark Gray Metallic.
• Color and Trim section-Added (49A) Double Silver/Silver Accent Stripe. It is available with all exterior colors except (15U)
Originally Posted by hvrod
Week of 12/10/2007
YEP!
