Power liftgate
Old 08-22-2024 | 09:51 AM
I have the power lift gate on my Ford Flex. Never missed not having one on my HHR.
Putting the power lift struts on the HHR would just be a small part of the whole install. You would need wiring from the BCM. Maybe a control button on the dash. And a separate key fob maybe ? Or a new GM fob with an extra button for the power gate.
Old 08-22-2024 | 11:52 AM
rwfnetworking's Avatar
Originally Posted by Oldblue
Those round plugs in the lift gate are access holes to factory installed rear spoiler.
No raining on my parade....:)
Thanks for the good info.
Old 08-22-2024 | 12:28 PM
PulpFriction's Avatar
This is place for honest, knowledgeable answers. If you want smoke blown up your tailpipe, Facebook is the place.
Old 08-22-2024 | 03:22 PM
Then there’s the safety aspect, a sensor system to prevent opening while driving. To ensure it’s closed . No way to load those parameters into the BCM
Old 08-22-2024 | 03:45 PM
On the few I've researched, this has been accomplished by only allowing operation when the vehicle is in Park or the Parking brake is set.
Old 08-28-2024 | 08:45 PM
Originally Posted by donbrew
That is a linear actuator.
I meant to ask you, are there other types actuators, besides linear?
Old 08-29-2024 | 02:12 PM
The hydraulic motors that are used to turn the wheels of dozers are radial actuators. Rack and pinion steering is lateral actuator. A screw thread is a linear actuator. A hydraulic ram is a linear actuator. The stepper motor that drives the blend door in your AC system is a radial actuator.
Old 08-29-2024 | 03:24 PM
So the picture that fadtsuv posted is not a linear actuator, since there is no rotary being converted to linear.
Old 08-29-2024 | 05:14 PM
You’re struggling with the actuator and that’s the easy part. For closing with electric actuators you need a whole different kind of latch. Good luck with that.
Old 08-29-2024 | 08:11 PM
I'm familiar with the various actuators, what I meant is what other types of actuators besides a linear one are used in a power liftgate?
cornwalis
05-27-2013 12:08 PM
astropods
2.0L Performance Tech
17
06-12-2010 03:09 AM
HHRNYC
11-14-2008 10:36 AM
PANEL1stnGA
10-23-2008 10:37 PM
da_dad66
2.2L Performance Tech
0
04-08-2008 09:03 PM
