Precut Window Tint
Precut Window Tint
I bought a "precut window tint kit" for the front 2 windows of my '06. I've always tinted my own windows in the past and figured this would make it slick & easy...
WRONG. The cut outs were WAY too large - almost 1-2" all the way around. I totally understand there should be a little extra to tuck into/under the sill area - but this was wayy too much. I tried 1 window and ended up throwing that one away - I couldn't tuck that much excess, just not possible.
I've emailed the tint company I bought these from - not sure what they'll tell me. Anyone else tried using these and had any luck?
When I had Dory's windows tinted, they tried using the precut ones from a computer program. After 15 mins of trying to put the film on, the installer scrapped it and started over doing it the old style from a roll of film.
The easiest way to get the tint on the HHR's windows is to pull off the weatherstrip that surrounds the window. The most difficult part about removing it is pulling away the top of the door panel so the bottom portion of the weatherstrip will come off. Once you get the windows tinted and dry enough the weatherstrip will push back on. It is important not to bend it too much. there is metal inside the weatherstrip that helps it hold its shape. I don't think I would drive without it on either. The window could break against the door frame if it is jarred enough.
![Thumb Up](https://www.chevyhhr.net/forums/images/smilies/icon_thumb.gif)
HillsdaleHHR
19
08-20-2009 10:35 PM
