Rear Lift Gate
Rear Lift Gate
Has anyone found a way to modify lift gate so it opens further (higher)? I load and unload my scooter a lot and when I forget to duck or stay bent over I bump my head. Was wondering if slightly longer gas struts would do it?
Yeah figured that might be the case,plus when I looked at it today - it looked like it won't go much further without hitting roof and thats assuming the hinges will swing further up. Unless someone says they tried it and it didn't work I will play with it someday to see if it is feasible.
Yes electric mobility scooter, I'm a disabled vet. I am very pleased how it fits in so I don't have to have an ugly external carrier. Just lay down steering and seat and hhr is perfect height that I can just lift front in and set wheel on bumper then pick up other end and roll it in . Works great.
yeah, put my wife's electric wheel chair in the back of mine. Bit heavier, use a set of fold up ramps. drive it up while standing on the ground. Don't worry about the noggin, but keep a careful eye on where the legs/feet are, just in case of falling wheelchairs...
raffmanlt......
Check to make sure the hatch is rising all the way. If the gas lift struts start going bad, they will not lift the door correctly.
Just noticed today my hatch misses opening all the way by about 3 inches. Found out by bumping my head
Guess I need to replace them.
raffmanlt......
