removing HHR and LT from back
Old 09-09-2006 | 12:04 PM
longhorn's Avatar
I was wondering what the easiest way to remove the lettering from the liftgate. I have used 3m decal remover and goo gone before on different vehicles, I was just wondering if there was an easier trick to it, without messing up the car or the letters (someone may want the HHR).
Old 09-09-2006 | 12:10 PM
courthousedeb's Avatar
It's my understanding that the easiest way to remove them is by using dental floss or fishing line behind them. Move it back and forth in a sawing motion until they are loose. It's just double faced tape that holds them on. Then use an adhesive remover to remove the sticky stuff that's left behind.
Old 09-09-2006 | 12:12 PM
Big Kahuna's Avatar
Longhorn...
I've removed them from many other vehicles in the past. If they are held on with the typical double sided automotive tape, I would suggest taking a hairdryer to them around the edges for a minute and they should loosen up enough to remove them with a slight pulling, fishing line or a credit card edge.
Be careful not to leave the hot heat from the hairdryer on the veh paint too long and work slowly and gently with the fishing line or credit card and you should have no problems.
BK
Old 09-09-2006 | 01:27 PM
Snoopy's Avatar
Yeap, I agree,,,,
Hair dryer is the way to go. It will soften the adhesive and the material the adhesive is applied to.....kind of like a black "super" double sided tape. Be careful with other tools that are used....you could scratch the paint.
Old 09-09-2006 | 02:50 PM
DARK AGE 53's Avatar
I just did this a week ago, used a hairdryer ( as other's have don't over heat the metal ) and PB Blaster to remove the residue.
Old 09-09-2006 | 02:54 PM
SoCalHHR's Avatar
Pulled mine right off with my fingers on a hot day.
Isopropyl alcohol will take off any residue left behind.
Be sure to add a good coat of wax afterwards for protection.
Old 09-09-2006 | 07:00 PM
dan-d's Avatar
Like Mike, I just gave mine a little pull and they came right off, I then cleaned the residue with some decal / sticker remover and a soft towel. I only used that stuff because it was available. Alcohol or Goo Gone would have also done the trick.
Old 09-09-2006 | 10:53 PM
thedonn007's Avatar
I grabbed mine with channel locks and pulled them off the day after I got home from the dealership. I also took off the GM squares on the doors
Old 09-10-2006 | 12:12 AM
Gambler's Avatar
Get rear ended and have the body shop move them when they are repainting it on the other guy's dime... thats what I did.
Old 09-10-2006 | 12:15 AM
longhorn's Avatar
I'll pass on the rear ending
