Replacing the stock horn
Old 08-13-2006, 12:56 PM
crowbar's Avatar
i went to autozone and boughta airhorn kit (sounds like ferrari or lambo horn) took the left front inner fender off cut the old horn wires and mounted the other one where the stock horn was and use the stock horns wires also.
only thing is youll have to replace your stock fuse with a 25 amp
crowbar is offline
Old 08-13-2006, 01:20 PM
Lee3333's Avatar
Was it hard to get the inner fender off? I would prefer my steering wheel to control my airhorns and not the wimpy factory one.
Lee3333 is offline
Old 08-13-2006, 01:23 PM
crowbar's Avatar
nope just a few push in screws and i think two bolts then the whole thing comes right out, the horn is behind the fog lamp
crowbar is offline
Old 08-28-2006, 12:50 PM
crowbar's Avatar
Did you take disconnect and remove the original horn?
i left the factory plug on the horn, cut the wires to use on the new one and removed the factory horn and tossed it in the trash can
crowbar is offline
Old 08-28-2006, 04:56 PM
en0oNmAI's Avatar
Why did you replace the Fuse with a 25? What is it originally?
en0oNmAI is offline
Old 08-28-2006, 07:47 PM
crowbar's Avatar
i think it was a 15, the first time the air pump ran for the new horn it blew the fuse
crowbar is offline
Joshua022
05-24-2012 11:11 AM
Joshua022
03-22-2012 08:04 PM
a76marine
"How To" Tutorial Library
07-08-2010 08:10 AM
StaticAZ
04-26-2010 05:42 AM
Quick Reply: Replacing the stock horn
