SS spoiler install info
Old 06-20-2009, 10:20 AM
Don Juan's Avatar
Is there a how to or pointers that people could give me on instalation. Got mine from Gm but no mounting hardware, and i looke at an SS and looks like the access plugs for the screws on the Non SS are non existant.
Any help would be appreciated.
Thanks
Stoney
Don Juan is offline
Old 06-20-2009, 10:46 AM
You should have gotten hardware, instructions and a template for drilling holes.
GDZHHR is offline
Old 06-20-2009, 10:52 AM
My spoiler I purchased did not come with a template. Thankfully the shop that I had attach it did a great job
HillsdaleHHR is offline
Old 06-20-2009, 10:55 AM
DLVRNIT's Avatar
Planning on this mod in the next couple of weeks and you are not the first to say that the hatch has no access holes from the backside? Ours has the rubber plugs so we assume this will make the installation much easier! No hardware? Maybe they newest spoilers are just taped on ?
DLVRNIT is offline
Old 06-20-2009, 11:07 AM
xzombiex66's Avatar
you have to drill 2 holes for it to work and also two access hole in the back of the tail gate, to make a template its a real pita, we used a piece of cardboard lol.
xzombiex66 is offline
Old 06-20-2009, 01:37 PM
jpmcnam58's Avatar
Here's how mine came...
Primered, with 2 outside threaded bolts (no nuts), 3 inside push in clips and 3m tape.
I was originally going to drill all 5 holes but changed my mind and ground off the push in clips and ended up just drilling the two outside holes...
I too made a template out of poster board...
This was one of many 'fittings of the template....
I will forewarn you, once you remove the backing tape and sit the spoiler on your HHR, you ain't moving it. I wanted to 'nudge' mine about a 1/16 of an inch after I placed it down....no figgin' way! My whole HHR was moving as I tried to move it. One thing is for sure, it ain't ever coming off!
I'm still disappointed that the spoiler did not come with a template or nuts for the 2 bolts!
Once I got it installed, I was a little less disappointed!
jpmcnam58 is offline
Old 06-20-2009, 08:10 PM
JB1
JB1's Avatar
wheres the finished pics
JB1 is offline
Old 06-20-2009, 08:20 PM
DLVRNIT's Avatar
https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/new-ss-spoiler-painted-beauty-bar-wiper-removal-24016/
DLVRNIT is offline
Old 06-20-2009, 10:33 PM
JB1
JB1's Avatar
thanks for the link, looks great.
Did you have the other rear spoiler before?
do you have to drill holes?...seems like that double sided tape might just do the trick
JB1 is offline
Old 06-20-2009, 11:56 PM
Don Juan's Avatar
what size of nut did you use and how big did you guys drill out the access holes?
Those rubber plugs on the normal hhr are not where the bolts go to dlvrnit. The SS has four rubber plugs.
Don Juan is offline
Quick Reply: SS spoiler install info
