SS spoiler install info
Is there a how to or pointers that people could give me on instalation. Got mine from Gm but no mounting hardware, and i looke at an SS and looks like the access plugs for the screws on the Non SS are non existant.
Any help would be appreciated.
Thanks
Stoney
Thanks
Stoney
Planning on this mod in the next couple of weeks and you are not the first to say that the hatch has no access holes from the backside? Ours has the rubber plugs so we assume this will make the installation much easier! No hardware? Maybe they newest spoilers are just taped on ?
Here's how mine came...
Primered, with 2 outside threaded bolts (no nuts), 3 inside push in clips and 3m tape.
I was originally going to drill all 5 holes but changed my mind and ground off the push in clips and ended up just drilling the two outside holes...
I too made a template out of poster board...
This was one of many 'fittings of the template....
I will forewarn you, once you remove the backing tape and sit the spoiler on your HHR, you ain't moving it. I wanted to 'nudge' mine about a 1/16 of an inch after I placed it down....no figgin' way! My whole HHR was moving as I tried to move it. One thing is for sure, it ain't ever coming off!
I'm still disappointed that the spoiler did not come with a template or nuts for the 2 bolts!
Once I got it installed, I was a little less disappointed!
