suicide conversion kit
Originally Posted by TruckSHOP.com
Door handles are going to be the least of your worries when you try to suicide an HHR. Assuming this is going to be the rear doors, the biggest challenge is going to be allowing the door to open more than just a crack. If you take a look at the Darkside HHR, they had to cut away the section of the door where it would have hit the fender. And even with that cut back it doesn't open very far.
There is no way a bolt-on kit for $500 will allow rear suicide doors to work, let alone provide Lambo doors in the same kit.
Someone will still buy it though...
http://www.cardoorconversion.com/ now some one will buy maybe me on the butterfly doors unless you feel it VERY difficult to do requireing much modification.
I have a bunch of friends with modified Fieros that have these things.. Personally I hate them. Having to open your door normally 10 inches and then raise it up. Most of the people I know just pull the door out and slide in unless they are trying to show off. Then they raise the doors. Not something we want on our HHR.
