Vinyl Diamond Plate
Old 02-06-2007 | 12:11 PM
FIRETRUCKHHR06's Avatar
Question Vinyl Diamond Plate
Has any one ever used any of this stuff or anythign like it?
http://cgi.ebay.com/15-Chrome-Diamon...QQcmdZViewItem
Old 02-06-2007 | 12:43 PM
en0oNmAI's Avatar
I can definately see some good uses for that!!! Good find!
Old 02-06-2007 | 12:54 PM
solman98's Avatar
I've seen it locally at auto parts stores (can't remember which). Kinda cheap looking IMO. It's one of those things, do it right, or don't do it. Too much fake stickon stuff is kinda tacky looking.
Old 02-06-2007 | 01:59 PM
I agree "do it right or not at all." But for some of the stuff I want to do the real thing just doesn't
look like it will work.
Old 02-06-2007 | 02:00 PM
tsaints1115's Avatar
El Cheapo
Old 02-06-2007 | 02:59 PM
Originally Posted by tsaints1115
El Cheapo
Well than what do you suggest I use.
Old 02-06-2007 | 03:05 PM
O6ChevyHHR's Avatar
I have seen this stuff used before, it turns out looking okay, Whatever you like the most.
Old 02-06-2007 | 03:42 PM
solman98's Avatar
Well, what are you trying to do? That might help.
Old 02-06-2007 | 04:01 PM
Holmes Hot Ride's Avatar
From the pictures, it looks like good quality stuff and has raised diamonds. As long as it butts up to something and you use it on a flat area then it probably will look fine. I can just see you using it for the firetruck look on the HHR. I was a firefighter from 1965-1772.
Old 02-06-2007 | 05:27 PM
SoCalHHR's Avatar
We use an acrylic material that is 3/16" thick. The diamond plate pattern is embossed inside and it looks much more realistic.
Example:
Hope it helps,
