What's the best way to get emblems off??
Old 04-14-2009, 06:33 PM
DANSHHR's Avatar
What's the best way to get emblems off?? curious, i like a nice clean look.
DANSHHR is offline
Old 04-14-2009, 06:38 PM
HHROwner's Avatar
I like to use fishing line to cut the tape,place it behind emblem and then saww it back and forth with pulling, then use goo gone or desolve-it to remove the remaining sticky stuff
HHROwner is offline
Old 04-14-2009, 06:55 PM
ballplr's Avatar
yep that's the way i did it
ballplr is offline
Old 04-14-2009, 07:17 PM
spirited driver's Avatar
I've always used a hair dryer- when the emblem gets hot enough, many times it can just be pulled off, although I've used fishing line too. (For reference, a hair dryer will not ruin the paint or do any irreversible harm to your HHR)
spirited driver is offline
Old 04-14-2009, 07:21 PM
birdflames's Avatar
I used an eraser wheel, just took a plastic putty spreader to get them off, and then the wheel to get the tape off the paint.
birdflames is offline
Old 04-14-2009, 07:52 PM
TEB-HHR's Avatar
If your not into fishing, you can also try dental floss, worked fine for me. Goo-Gone also cleaned off the rest of the residue.
TEB-HHR is offline
Old 04-14-2009, 08:03 PM
BigMOCats's Avatar
I just grabbed them and pulled, then used my thumb to rub off any extra 2-sided tape. Cheap easy, efficient, no tools, just go slow. A hot day does help (hairdryer). I've been doing this to cars for ever w/o any problems. Thank God they don't rivet them on anymore, that was a little more work!
BigMOCats is offline
Old 04-15-2009, 07:50 AM
esmarkey's Avatar
And they don't have the locating holes either. I pulled one from the tailgate on a suburban and there were 2 holes that had to be filled and painted. The emblem was only held on with double sided tape, but it had 2 post that went into the holes to make sure it was on straight. The new method is much better!
esmarkey is offline
Old 04-15-2009, 10:08 AM
LTSport08's Avatar
that was the easest way for me to do it too
LTSport08 is offline
Old 04-15-2009, 01:59 PM
ecl
ecl's Avatar
Floss and Goo-Gone worked for me
ecl is offline
Quick Reply: What's the best way to get emblems off??
