12 V ignition / switched power source
Old 05-14-2006, 12:29 AM
ng8650's Avatar
Originally Posted by jaydogg
here is an other note to self for ya my aim is enocjcornelius, if im on there i can help alot quicker than over this forum, just ask cj.
aim....Guess now I'm going to have to sign up
ng8650 is offline
Old 05-14-2006, 12:59 AM
cowboybornlate's Avatar
no aim here, yahoo, msn, excite (what there is of it anymore) and I have an ICQ, but I can't remember my password for ICQ from years ago... lol
CBL
cowboybornlate is offline
Old 05-14-2006, 01:26 AM
jaydogg's Avatar
CBL
msn - jaydogg183@hotmail.com
jaydogg is offline
Old 05-14-2006, 12:24 PM
laylowcustoms's Avatar
I do have a mulitmeter and I have tested and made sure all my wires work correctly. Used the large wires from the fuse box for the power and used the car body as a ground.
That color code doen't seem right. Do you have the premium sound option? GM has always (accept bose) used
LF +tan, -grey RF +Lt. green, -Dk. Green
LR +Dk. brown, -yellow RR +Dk. Blue, -Lt. blue
and most gms use a orange as constant and yellow as switched and a black or black/yellow as ground. Newer cars have started to defferinate from the power side but not the speaker side. I tested this on my car with the mulitmeter and these are the correct colors for my car. I "poped" them to make sure.
laylowcustoms is offline
Old 05-14-2006, 01:23 PM
jaydogg's Avatar
i dont have the premium stereo because i knew i was going to tearing it out. i used the codes that i posted and they worked and have been for almost 3 months now.
jaydogg is offline
Old 05-14-2006, 02:28 PM
  #26
dbarberaz's Avatar
Just do not cut the red white green and blue pokka dotted wire. That is the reset button
dbarberaz is offline
Old 05-14-2006, 02:32 PM
  #27
ng8650's Avatar
ng8650 is offline
Old 05-14-2006, 02:55 PM
  #28
Navyflyer11's Avatar
Hope this helps.
item___________________wire color_______polarity_________location
  • Radio 12v___________red/white__________+___________radio harness
  • Radio Ground________black/white_________-___________radio harness
  • Radio Ignition________(GMLAN Serial Data)
  • Radio Illumination______gray (dimmer)_____+___________radio harness
  • Factory Amp Turn-on______same as power antenna wire
  • Power Antenna_________pink____________+___________radio harness
  • LF Speaker +/-________tan - gray_______+,-__________radio harness or amplifier
  • RF Speaker +/-______lt. green - dk. green_+,-__________radio harness or amplifier
  • LR Speaker +/-______brown - yellow______+,-__________radio harness or amplifier
  • RR Speaker +/-______dk. blue - lt. blue____+,-__________radioharness or amplifier
Navyflyer11 is offline
Old 05-15-2006, 06:26 AM
  #29
thats the wiring format i've used.
Hey JayDogg, does your radio fade and balance?
Old 05-15-2006, 10:51 AM
  #30
jaydogg's Avatar
yep it fads and balances the way it should.
jaydogg is offline
Quick Reply: 12 V ignition / switched power source
