2007 HHR stereo upgrade
Hello!
I bought a 2007 HHR project a few weeks back and am wanting to add satellite radio. I know I would need a head unit with the "CAT" button, an antenna, and the receiver but what else would be needed for an install using factory components?
Are steering wheel controls a "drop in" upgrade? What about onstar? Not sure if I will go that far but it would be nice to know out of curiosity.
Mike
Mike
Here is a thread on xm radio upgrade. https://www.chevyhhr.net/forums/audio-video-17/adding-xm-radio-2008-a-20883/
The radio steering wheel controls and an easy upgrade. It can be done on your radio you have now. Here is a thread on that. https://www.chevyhhr.net/forums/show...steering+wheel
You can get more info on this by using the search bar at the top of the page.
Thank you for the links.
Which CD players will work with what I have (pure base model most likely)? What are the differences between the regular CD player and the 6-disc changer aside from the obvious?
Thanks!
Mike
Thanks!
Mike
My Lucky 2006 HHr
Well I have an 2006 HHr LT2 & a 2007 Pontiac G6 GT, I just replace the Head unit in my G6 and it was a doozy, first after buying an 7" DVD, Backup camera, Ipod, Aux, USB connector, SD Card reader, Bluetooth, Navigation, double Din aftermarket unit, I had to also purchase a Metra 95-3303b DIC unit, because it had to be installed into my glove box because of the DD unit, all because they put the DIC in the Head unit of the G6, also had to switch my Xm radio over to the mobile sport unit costly but worth it, but on my HHr I won't have to worry about all of that if I change the Head unit.
https://www.chevyhhr.net/gallery/fil..._head_unit.jpg
https://www.chevyhhr.net/gallery/fil.../9/dic_box.jpg
Rogoflap
05-14-2010 02:03 PM
