Adding factory amp and sub
Hello guys I was needing to know I have a 2007 HHr and it did not come with the factory amp and sub that goes int he back But I found a new one and I was wondering can I add this like a plug and play or will I ned to run all the wires for it?
Yeah I just took delivery of my 2011 HHR without the Pioneer system and I looked behind the panel in the back...noooo harness. Even if you order the harness from a dealership going from the head unit back, going to cost $$, you still might need some kind of control module according the parts manager I spoke with. All I'm looking for is to get signal to back so I can run a mono amp. I'm hoping the 'PAC AOEM-GM1416a GM Add an Amplifier Adapter' will do the trick.
