aftermarket double din wiring harness 09?
I'm talking about a harness for a aftermarket double din cd player. I was surprised when noone could tell me what i needed considering alot of users on here talk about double din's. I'm wanting to get a kenwood but idk if their is a harness for it.
Double din or single din, they all use the same harness.
You probably need a newer version of the GMOS-LAN due to Bluetooth, but your best bet is as stated above, check Crutchfield "outfit my car."
Doesn't exactly take a rocket scientist to figure out.
And if you got a Cobalt, someone would've already told you to F off, and search for the other hundreds of threads that have already covered the issue.
I dont have a cobalt and i did crutchfield.com which doesnt list anything for my car an 09. So idk if i should get the metra gmlan04. Considering noone has tested it or used one on a 09 that i know of.
