aftermarket double din wiring harness 09?
Old 05-16-2009, 08:01 PM
HHRthunder13's Avatar
anbody know a wiring harness for the 2009 hhr LS.? I"m looking for one and cant find one.
HHRthunder13 is offline
Old 05-17-2009, 12:51 PM
wow no help on chevyhhr.net. Bummer shoulda got a cobalt.
Old 05-17-2009, 04:57 PM
ChevyMgr's Avatar
A cobalt...geeesh... Since there are more than one, maybe telling us what harness you want might help.
Try LKQ they specialize in used parts. If you want a new one call a GM dealer.
ChevyMgr is offline
Old 05-18-2009, 06:28 PM
I'm talking about a harness for a aftermarket double din cd player. I was surprised when noone could tell me what i needed considering alot of users on here talk about double din's. I'm wanting to get a kenwood but idk if their is a harness for it.
Old 05-18-2009, 06:35 PM
ChevyMgr's Avatar
I can't help you on that. But I can fix the thread title to get more attention. Goodluck with your quest.
ChevyMgr is offline
Old 05-19-2009, 11:02 AM
prod's Avatar
Ah, the radio harness.
Its probably the same as 2008, a metra gmlan03 if you dont have onstar, gmlan04 if you do have onstar.
prod is offline
Old 05-19-2009, 08:38 PM
Rcflyboy's Avatar
Try crutchfield.com and see what thier web site suggest. Most likely the GMS-LAN3
Rcflyboy is offline
Old 05-20-2009, 03:34 PM
Tuanies's Avatar
Double din or single din, they all use the same harness.
You probably need a newer version of the GMOS-LAN due to Bluetooth, but your best bet is as stated above, check Crutchfield "outfit my car."
Doesn't exactly take a rocket scientist to figure out.
And if you got a Cobalt, someone would've already told you to F off, and search for the other hundreds of threads that have already covered the issue.
Tuanies is offline
Old 05-20-2009, 07:54 PM
I dont have a cobalt and i did crutchfield.com which doesnt list anything for my car an 09. So idk if i should get the metra gmlan04. Considering noone has tested it or used one on a 09 that i know of.
Old 05-20-2009, 08:26 PM
09 Panel's Avatar
How about calling Crutchfield and asking if they have newer info than they have on the website.
09 Panel is offline
Quick Reply: aftermarket double din wiring harness 09?
