aftermarket HU install
will it hurt the cars computer by just hard wiring up my stereo? I have went through numerous wiring harnesses and none of them are the right ones... i have a 08 2LT... the last harness i used put my vehicle in lock mode making it so i couldn't turn it over... i dont care about the chimes or turn signal sounds... can i just hardwire it and not even worry about the harness?? plz help me out...
Mine is hardwired in. I cut the factory harness for the constant and ground. I also spliced into the door speakers behind the deck. I ran a switched wire to the fuse box. I think, I may have ran the constant to fuse and spliced the switched. I would suggest grounding the HU at the same location as the amp in the back. I got to move mine from the front. I got a horrible buzz noise with my new radio coming from a bad ground. Also if you hafta run RCA's run them down the middle of the car if possible.
It shouldnt be that hard to find the wiring harness.. I just looked up on ebay and found the wiring harness and install kit for like 15.00. From what I understand, there are only two kinds of systems in our hhr, regular nonamplified and premuim, I could be wronge though about the two types.
wut exacly did you do?... im talking about not using a harness at all jus cutting the wires and hardwiring it all... i am afraid if i cut the wires that i wont be able to put anything in if it doesn't work... plz give me a detailed description on wut u did... thank you
