aftermarket radio
Old 02-10-2020 | 09:56 PM
Joe Reed's Avatar
aftermarket radio
so i have an 08 Panel. it has the stock OE radio. i wanna get a ne aftermarket installed to i can install a sub later on. My car has Onstar which i don't use and never plan on using also it has NO buttons on the steering wheel... Iv done some research and keep coming across come "interface device" do i need this part. I have oned many car and its normally just a cheap plug adapter and wham bam you're done.... Does the HHR have screwy wiring that im gunna have to dick around with? or should i be ok just getting the little wire adapter like every other car....
Old 02-10-2020 | 10:32 PM
A. the radio is connected to the BCM Via the Serial data lines to produce the chimes. Need an adapter.
B. the factory harness does not provide a switched circuit, That also comes from the serial data line.
C. there are lots of examples on this forum of folks that "have installed radios in other cars" that have botched the job .
D. do you have the factory amp and sub woofer?
Old 02-10-2020 | 10:38 PM
Sounds risky... Installing a brand new stereo in a car that you can't lock the doors.
Old 02-10-2020 | 10:53 PM
Joe Reed's Avatar
Umm
How would I know??
Old 02-10-2020 | 10:54 PM
Joe Reed's Avatar
Lol
Hahaha. I can manually lock them lo . Just the remote doesnt work
QUOTE=RJ_RS_SS_350;885171]Sounds risky... Installing a brand new stereo in a car that you can't lock the doors.[/QUOTE]
Old 02-11-2020 | 01:44 AM
Originally Posted by Joe Reed
How would I know??
If you don't know, if you have a sub etc., you probably would be best to just take your HHR to a shop and have them install the new stereo.
Old 02-11-2020 | 06:48 AM
You can look at the drivers side rear interior panel , if it says Pioneer chances are you have the seven speaker upgraded system or look at the RPO sticker on the inside of the glove box door.
Then again a PO might have changed that panel for some reason.
Another way to determine, take the oblong access door off and look inside the amp will be in there
Old 02-11-2020 | 02:55 PM
Lethal Tendencies's Avatar
I would go to crutchfield.com and type in your vehicles info. They will show you the wire harness and chime box you will need for aftermarket hookup.
Old 02-11-2020 | 03:33 PM
Then take the part numbers and shop on eBay/Amazon for a better price. The circuit boards are "cheap Chinese generic".
Cliffs51
07-26-2018 09:17 AM
Winston Wonderland
10-06-2017 01:08 PM
serenity1986
12-01-2014 11:08 AM
Old Lar
09-08-2014 06:30 PM
nismo_8803
07-03-2014 09:05 PM
