Alpine double din not working with iPod
Hi I have a alpine Iva-w200 and I just got the car and my iPod will play two songs maybe and when it switch to the new song it will play ten seconds and switch again. So me and my fiancé switched out iPod with hers and didn't have a problem and she has the second gen and mine is the fourth gen didn't know if that could be the problem.
And I would like to also know if anyone knows how to down load the back grounds to them I was reading that you could put your own back ground.
Check the Ipod software versions. I pulled this straight from the owners manual.
About iPod usable with this unit
The unit can be used with third generation and above iPod, iPod photo,
iPod minis or iPod nano. iPod Shuffle cannot be used, however.
• Touch wheel or scroll wheel type iPods without the dock
connector cannot be connected to the unit.
• The unit can be used with the following iPod versions.
Correct function of earlier versions cannot be guranteed.
Third generation iPod: Ver. 2.3
Fourth generation iPod: Ver 3.0.2
iPod photo: Ver.1.1
iPod mini: Ver. 1.3
iPod nano: Ver. 1.0
• The unit cannot be used with the software versions earlier
than “2005-02-22”. For details about “iPod Software
Update,” refer to the iPod Instruction Manual
iPod photo: Ver.1.1
iPod mini: Ver. 1.3
iPod nano: Ver. 1.0
Check the playback options on the head unit/ipod
10 seconds sounds like the old function on CD players that just played the first 10 seconds and skipped to the next track.
So look around on the unit for playback options or, you know, read the manual.
