Alternator---how many amps?
You asked the same question about this time last year...here's that thread with info you should need.
https://www.chevyhhr.net/forums/general-hhr-4/chrysler-group-give-free-gas-car-317/
https://www.chevyhhr.net/forums/showthread.php?t=317
Should be https://www.chevyhhr.net/forums/audio-video-17/alternator-how-many-amps-3177/
Instead of a redirection, I'll just tell you that it is 130 amps according to Chevy's website. I've been looking into this as well, but if you happen to get it done first, you gotta post results, dude!
Copperhead's question signifies to me that he has bigger plans, and wants to do it "right."
In the interest of trying to help you once again...if you know you started a thread, the easiest way to locate it is to click on your username on a thread and view your own profile. Then you can click on view posts started by copperhead and all the posts you started will be there. You can also click on My Posts at the top of the forum and look through those as well...there is only 35 to look through.
Last edited by courthousedeb; 10-27-2007 at 10:07 AM. Reason: correct spelling error
Here is the correct link referenced above:
I hope this helps as well.
Alternator,..how many amps?
Well duh, I see that was also mentioned above!
