Amateur radio (ham radio) installation
I hated to thread jack the GPS location thread, so I will ask here where it is more appropriate.
Can anyone tell me if there is a single HAM unit that will also include the CB band? If so, what make, and suggestions on places to buy.
I know I need a license, but want to see what is available before I consider doing this.
On a long shot, would also be interested in including the VHF band on the same unit....
Possible HAM, CB or Cellular Antenna Mounting
Here is how I mounted my GPS antenna; it is directly above the front overhead interior light allowing easy cabling access. A short fish to the A-Pillar, remove A-Pillar trim for easier access and the plastic cover at the end of the dash and the cable is routed.
A move 6 inches to the aft is roof bracing that would allow a bit more strength and a standard ¾” hole for a vertical antenna. Drill from the outside, insert between roof and headliner the ¾” threaded/molded cable assembly, attach antenna, adjust SWR and enjoy.
Possibly investigate the rear passenger interior light area as well for a support.
If you’re worried about drilling into the headliner pick up one of these ¾” drills or similar. It limits the depth of cut. Don’t ask me where I got it, its been 15 years ago when I was doing cellular installs.
Now for those people who have some emotional bond with their vehicle and don’t like drilling holes: My vehicle is nothing but an inanimate object, a collection of metal and plastic in a form that provides some usefulness. Don’t believe me; hit it with your fist, it will not scream out in pain.
If you’re worried about resale put something like my GPS antenna on the hole when selling it. Say it is GPS ready!
I don't know if the 857 will work on the CB band, I think it may receive it but it may be blocked on the transmit side. I was at a CB shop today and they had radios that had the CB frequencies as well as the 10 meter ham band. they were not cheap though.
#26
FT857D Install
I just got the HHR last week and ordered an FT857D for it yesterday. We have one in the wife'sd PT Cruiser and it was a simple and trick install. THe HHR looks harder but here's my thought. I might put the head on the ceiling just abouve the rear view mirror. Easy to get to, easy to see without taking your eyes too far off the road. THe Lido Bug looks pretty useful however and I may check it out before drilling in the headliner, unless I just fall in love with the head on the headliner when I try it there.
Jim N5VL
Jim N5VL
#29
Jim N5VL
Jim N5VL
#30
I guess the only reason it wasn't allowed by "type" certification is the 857 can put out more power than CB Transmissions allow.
The manual I downloaded does not say the actual frequencies the unit transmits on, only the general bands.
