Antennas ?? Which is Which
I thought I knew it all but now Im' confused.
I took my front antenna off the other day to check for wind noise and I could not tell any difference in reception on AM or FM.
I then went to my owners manual to check it out and it does not specify anywhere I could find which antenna is which.
On my 2LT I have the ugly front and the rear antenna.
Plus it looks to me that there is an antenna molded into the front windshield.
So ... we have AM ...FM ...and On Star.
I could call Chevrolet but I thought I would bring this subject to the Forum to clear the mystery up.
Anybody know for Sure whats what ??
SF
SF
Forward antenna - AM/FM receiver.
Rear antenna - XM radio(if equipped), and OnStar.
If you're in an urban area with good coverage, the forward antenna can be replaced with a "stubby" accessory antenna as the signal strength will compensate for a shorter mast. And you can run without it as you found out.
Thanks Mike,
Whats the front winshield dots in a pattern I'm seeing.
They go up on both sides and across the top with a big drop down behind the rear view mirror.
My 2005 Chevy Venture Van had no external metal antennas but the front windshield looked a lot like this one. ?????
Those dots are a paint mask that's intended to block the sun from shining in through the gap between the sun visors. It's supposed to make up for the old style blue tint strip across the top of the glass.
Safelite offers HHR windshields with the tint strip, and if you ever need to replace your glass, I can't recommend it highly enough...it makes a world of difference.
I remember the old GM integral windshield antennas, they sure made for clean designs, but manufacturing expenses and poor reception in fringe areas did them in.
I thought I had ya on that one .. I shoulda known better.
I'll make a mental note on Safelite.
These near straight up windshieds are a magnet for rock damage.
I have had 2 hits in exactly the same place ??? I thought I was dreaming.
They happened so close together that I hadn't gotten to the shop to have the first one repaired when I got the second .. a larger hit on the drivers side right at the bottom margin. They repaired it but said it was borderline and could still possibly spread to the edge.
It seems like the HHR wind flow might take the small objects to that exact area. Otherwise what are the chances of that happening and in such a short time frame.
Thanks,
That's the twist on "shark fin" portion of the antenna, GM list price is $28.08, but a quick Google search of that part number will net you one in the $15-$18 range.
