ATOTO android radio installation question
I tried to explain that there is no switched wire in the OE harness because that part is handled digitally by the computer.If you don't use the interface you will not be able to use steering wheel controls or have "door open" chimes.
If you need to find a source for switched 12V look on the BCM (the inside fuse box, below the radio) There are 3 fuse locations marked "spare" they are unused switched circuits, 2 20A 1 10A. If you don't understand tapping into a fuse box maybe you should find someone who does.
If you go to the crutchfield.com site you will find a wealth of information regarding installation. Your particular model does not really matter in regard to what wire is what.
I was not offended, just didn't know why you would be shouting after you had acknowledged the answer. That only gets you negative attention.
