Batterys
I use Kinetik Audio 2400s. They are big, but they fit, I have 6 in there right now.
Kinetik also makes smaller sizes if you want to stay close to stock. They make an 1400 and 1800 close to stock size but as much CCA as 2-3 stock batteries.
Kinetik's have an extremely low ESR which means they will charge from the alternator easier than a lead acid battery reducing strain on the alternator. They also have a very low self discharge rate which also makes it a good battery to use multiples of or use with other types of batteries. This is because you have very little to no current flow between batteries connected in parallel so they wont heat up the cells reducing battery life.
Basically, they are powerful and reliable.
speaking of batterys, can some one tell me a good battery to replace stock one, that will fit in same area, need higher amperage to power my laptop and printer, I have a solar panel, but sometimes, it just doesnt do the trick. Brand, size, part number, would be appreciated.
check this out. I dont recall the exact size of the OEM battery, but they have several sizes to choose from
http://kinetikaudio.com/hc1400.asp
I have ODYSSEY 1500 battery it is not a bolt in replacement but its not a hard install. They make the stinger power 2 batteries. http://www.odysseybatteries.com/index.htm They also have a 4 year replacement warr. Great batt.
