Coaxial speakers vs. component Speakers.
whats the biggest advantages from standard Coaxial speakers compared to component speaker systems. Yes component speaker systems would cost a bit more. and should make the sound spread and more clear better.
Any Knowledgeable input and know how is appreciated.
You dont necessarily need an amp for components. It all depends on the power rating of the components. As far as the sound goes, the components will give you tunability of the soundstage. The coaxials are at a fixed location whereas the comps you are able to move the tweeter around. Companies also generally speaking use better parts in components than coaxials.
As soon as I got my HHR in 06, I switched all 4 door speakers. Much improvement. Down the road, I changed the head and used the internal amp plus a separate one for the new sub. Eventually I got all new door speakers-Polk-and used component for the front, co ax for the rear. I put the tweeter in the pillar. I tried it in different places, and the pillar gives the best sound stage. For wiring, I did it the easiest way possible. I have the amps in the back, so I ran the wires to the factory amp and spliced into the factory speaker wires. I put the 2 crossovers in the compartment by the drivers rear tail lights. The only new wires I had to run are for the new tweeters. The reason for all this was to avoid new wires to the doors, which is a pain in the a$$.
