Dash Waterfall Panel Won't Re-Attach
I took the waterfall off to mess with some of the wires behind the Radio. Radio and Heat/AC Controls went back in fine. The top of the waterfall attaches fine, but the bottom 2 clips just do not want to stay in. I've checked all I can to make sure all the wires are going back where they should, but can't for the life of my figure out what's keeping it from going all the way in.
Any suggestions?
Any suggestions?
The bottom of the panel must be put in first. There is a tab that must go behind the bezel. Then work you're way up to the top. I did the same thing when I switched head units. I finally figured out how it is done. with the panel off look at the bottom you will see the tab.
Thanks for the tip! I got it back on.
Thought I was going to break it though. Was tough to get that lip in, then the rod didn't want to go into the notch, between the wiper controls and the 12v outlet, but some finagling got it in.
andoll83
11-02-2008 11:12 PM
