Direct Wiring for 2006 HHR with 7 speaker system and Amp
(for those who choose to keep the factory amp and change the head unit)
(or those who wish to use the factory amp with a carputer)
[Harness 1]
Battery(+) = [RED/WHITE]
Ground(-) = [BLACK/WHITE]
Left Front Low Level = [DARK-GREEN(-)] [TAN(+)]
Right Front Low Level = [LIGHT-GREEN(-)] [LIGHT-GREEN/WHITE(+)]
[Harness 2]
Amp Turn On Signal (same as power antenna) = [PINK]
Left Rear Low Level = [BROWN(-)] [BROWN/WHITE(+)]
Right Rear Low Level = [TAN(-)] [DARK-BLUE(+)]
The ignition line will have to be sourced elsewhere
as it is controlled by the GMLAN.
Check the fuse panel to the right of the center console for a source.
[Hint](Power windows work after you shut off your car, until you open a door!)
[Harness 1]
[Harness 2]
[Harness 1]
[Harness 2]
[Harness 1]
[Harness 2]
You can also grab accessory at the ignition harness
It's the brown wire there
[Harness 1]
[Harness 2]
[Harness 1]
[Harness 2]
http://n8zcc.com/pics/HHR/Audio_Connectors.pdf
