Gmos-lan-03
Gmos-lan-03
This is my first post, so if I missed the answer to this in the past, I apologize.
I bought an aftermarket stereo and of course the Axxess GMOS-LAN-03 adaptor. On the 16 pin plug, there are 2 red wires. The instructions call for one red wire to be hooked to head unit. Anybody know which red wire I use, and what is the other red wire for? Axxess instructions are pretty sub-par. Thanks!
At the connection to the factory harness only one of those red wires will have a factory wire on the factory side. That is the one you use. Not sure about the other but I imagine it might be used on a different vehicle since these harness adapters service several vehicles.
