HHR Lap top mount?
HHR Lap top mount?
Has anyone looked for or found a Laptop mount that bolts to the seat rails?
I have found a few that require drilling into your floor pan with Self tapping screws but I am not ready to do that yet.
Thanks in advance
Thanks in advance
knelson, so far as I know there are none that attach to the rails, however, I know one that will attach to the console on the passenger side. again with a couple of screw, however, it can be rigged up to do just what you need. Would you like to view one of the products of which I speak?
From what I am reading, unless you reinforce the center console in the front where you are going to mount this it may not work just right. so maybe what you will have to do is mount a metal bracket on the back of it and bolt the laptop mount through the plate and the console.
http://www.galls.com/style.html?asso...t=&style=VE222
