iPod hook-up
looks like a 3' or a 2' to me (1' is really short an your cable would not coil like that at that length). I wanted a 1' bad, but it was a lot harder to find. Opted not getting it and at some point (probably when i stop paying for XM) i will get the PIE cable which is an audio jack on one end, a springy coiled style cable, and then the 30pin dock connector on the other end.
The most interesting part of this shot to me is your window switch area, never saw the setup for a panel. At first i was confused where your buttons went, then i figured it out.
the pie cable:
http://www.discountcarstereo.com/detail.aspx?ID=1035
the pie cable:
the pie cable:
the pie cable:
7cm? 20cm? Retractable? Besides the retractable, 7cm is the shortest I have seen, that is around 2.75". 20cm is around 8 inches. Radtech is a good company. You don't want to go with the $1 cables you see on amazon or ebay, etc, not if you like sound quality. Plus you can get them in black. The PIE is the only one i have found that goes dock to 3.5mm jack, in black, that isn't super long.
http://www.radtech.us/Products/CablesIpod.aspx
