Kappa One - Install Help Needed
Old 09-17-2009 | 12:01 AM
Spawn21's Avatar
I just purchased an Infinity Kappa One amp. I am so confused about hooking subwoofers up and what I should be looking for.
The amp is a mono block amp. Which means there is only one channel, but there are 2 positives and 2 negatives. They are internally wired in parallel. The amp is rated at 500 watts RMS at 4ohms and 800 watts RMS at 2ohms.
What are my subwoofer wiring opinions?
Old 09-17-2009 | 12:05 AM
Father Azmodius's Avatar
Your wiring options depend on what sub/subs you plan on using. What are your plans as far as how many subs, and whether they'll be single or dual voice coils?
Old 09-17-2009 | 12:14 AM
Spawn21's Avatar
Well, I have 2 Pioneer Premiers. 4ohm DVC rated at 1000 watts RMS. I know I can't run both due to the underpowering factor.
I was thinking, if it was possible to run one of these speaker at a 2ohm load, it should be fine. I don't think underpowering a subwoofer by 200 watts would cause too much harm.
If that wasn't possible, I was going to go shopping for a new subwoofer setup to match the Kappa One. I tried to call the support hotline for Infinity, but couldn't understand what they were saying.
Old 09-17-2009 | 12:20 AM
Spawn21's Avatar
Here is what I got:
Kappa One - Specs
Pioneer Premiers - Specs
Old 09-17-2009 | 07:52 PM
Spawn21's Avatar
Any help at all??
If somebody could find diagrams for different subwoofer setups for "internally wired in parallel" mono amps would be great. Please post a link.
Old 09-17-2009 | 08:31 PM
Rcflyboy's Avatar
Go to wwwCrutchfield.com there is a how to section on different ways to wire amps. All the info you should need is there.
Old 09-18-2009 | 04:15 AM
Spawn21's Avatar
Thanks for the help. After digging around and what not, I found my answers.
I'll be honest, I expected more from a Kappa Series amp. I'm not too impressed. I'll buy better subwoofers though and see if there is any difference.
Old 09-19-2009 | 04:05 AM
jerseymike68's Avatar
Great coordination
jgoldwood
04-20-2010 09:43 PM
goatcheez
07-26-2009 09:24 PM
220
7
04-11-2009 10:42 AM
Sunrise HHR
08-14-2008 01:55 PM
BlackHHR06
01-30-2008 10:30 PM
