Looking for XM ID Code
Check your build tag in the glove box, if you don't see code U2K which is the XM radio option, you will have to install the XM module/wiring harness pigtail/antenna in order to receive the XM signal.
If you're HHR is an ex-rental/fleet vehicle, you will probably see code U2J which is the XM radio delete option commonly found on fleet vehicles.
NxlKing2304
02-14-2014 07:41 AM
