This this may be a first...
#81
Originally Posted by snova031
North Babylon
For the XM, I needed the Terk XMD1000 universal tuner and a cable that converts an 8-pin mini din to a db9 serial plug.
If you were in Cali - I'd have you building those things right and left!
#82
Thanks would this work ? http://www.samash.com/catalog/showitem.asp?ItemID=45661
#83
The pin outs might not correspond to the correct wires...it may/may not work.
I picked up this one-
http://hybrid-mobile.com/products_interface_cable.php
They have 2 versions- one with built in LED's and one generic cable...I picked up the generic one for $25, works great.
#85
Does anyone know why I cant get an xm pcr to work with centrafuse It shows the channels but theres no audio, but when I use the software that came with the xm pcr it works fine..I've checked tha audio settings, com port settings and its set to xmpcr on centrafuse, So I dont know..
#86
I'm not all that familiar with Centrafuse...check the .ini settings in Centrafuse and see what input XM is set to.
#87
have you checked XMFan.com?
-wC
