More bass without putting in a box
i want more bass without putting in a box in the back of the car, is there a way i can replace the factory sub with a little better one or something, i need all the space i can get. what can i do??
thanks, mike
thanks, mike
Have a Look at this, a Budget HHR audio build.
http://www.truckinweb.com/tech/elect...dup/index.html
What brand and P/N sub, if you don't mind? Also, did you wire it in to the stock Pioneer amp, or add a new amp? I'd love to be able to just add the sub if that was all you did to get better bass!
thats what i want, what sub did you use and can i have some pictures of it? i really want to see what you did, can you give me all the information that you used?
this is what I put in mine:
http://www.amazon.com/Infinity-Bassl.../dp/B000063TJY
It has 2 10's and an amp. It's all one unit, it's small, and it fits perfect under the spare tire. It's not to much at all...it just sounds really really good...more like a louder, more bassier factory tone. You can probably get them on ebay pretty cheap.
I also hooked mine up using the factory CD player using a "line out converter" that way I was able to keep my factory CD player.
