Need some stereo gurus
Hello i have a 2007 ls stock radio and was replacing my front stock speakers so i put in a pair of scosche 6.5 HD 6503 250 watts 4ohms and hook them up and the work great but know my rear stock speakers are not working and i check the balance front and and rear set them to 0 and still no sound from stock back speakers ... I know the rear are 8 ohms stock and can not figure out why they don't work when they did before the front were changed ,maybe i am old school but need some input thanks ..
Running 4ohm and 8ohm speakers at the same time on the same amplifier won't work. You're presenting the amp with different loads. I replaced all 4 of my factory speakers with 4ohm speakers and they work fine. If you put the 8ohm speakers back in all 4 will work again. Not what you want you wanted to hear...sorry.
Ok will right from the factory were setup with 4 ohms front and 8 ohms in the back ,so i figure if i replaced the front with 4 ohms and leave stock 8 ohms in the rear they should all work right? well that is all i did and my my stock rears have no sound weird...
In my 08 panel, all of my speakers are 4ohm stock, I would even out the load all around either 8 or 4ohm all the way around and all should be good again
You are powering 250w rms 8ohm speakers from a stock unit? No wonder you don't hear anything.
You are sending less than 15-25w rms to 250w rms handling speakers. Shame on you.
Not to mention that you probably see half that (10w rms) since the ohm load is higher
. You need to read the stock rear speakers are 8 ohms that I never touch
I had some stereo problems of my very own, that's what brought me to this site in the first place.
Yes in my '06 the front stock speakers said they were 4 ohm and the rear said they were 8 ohm. This was printed right on the back side of the magnet.
I thought this was a little odd because I have a little background in electronics, but figured who ever specked the amp in the stock radio might know what they were doing.
I replaced all 4 stock speakers in the car because they had stopped working in the HHR.
I'm incredibly cheap and really hate to buy new stuff so I tinker with stuff a lot and after applying some WD-40 to the frogs in the speakers they started working again. When I put them back in the car they would only work for a day or so then quit working again, so I removed and replaced them then built some enclosures for them and am still using them in the garage.
I have no real clue why the work fine in the garage but they do.
Well thanks to all reply's but i am going to buy another pair of the same brand install the same set speakers i bought for the front and put the same ones in the rear to equal out ,so 4 ohms in front 4ohms in back and see what happens
I have read this entire thread and you may have received a little misinformation . There is nothing wrong with running a mixed load over 4 channels . We all do it or have done it . I am doing it now with the 200.4 Phoenix Gold amp .... Front 2 channels 4 ohm , Rear channels summed mono at 2 ohm . The 4 ohm/8 ohm will not damage your electronics .
RMS power rating/ sensitivity rating ..
The power rating of a speaker is the range of wattage the speaker will operate properly in . Nominal 125 Peak 250 .
Sensitivity rating is how loud the speaker will play at "1 watt at a distance of 1 meter " .
The higher the number the more efficient the speaker . The result of a number like 96db sensitivity rating says that speaker will be 6 decibels louder than a speaker rated at 90db . This testing is done with 1 watt . You must double your power for a 3db increase . A 6 decibel increase can be achieved by only choosing the correct speaker .
My tweeters are rated at 90db . Power range with a PMAX of 75 watts . I doubled up on the wattage for each tweeter because of the sensitivity rating . That rating told me that they would demand power to perform . So they have 142 watts per channel each . That amount of over kill is not necessary, but we have different objectives in our systems .
Hope this helped you to understand that number you put out there and some of the responses you received .
Greg
