New speakers/tweeters
Old 03-26-2012, 03:18 PM
Joshua022's Avatar
Throwing in some new Infinity speakers throughout the car and some new tweeters!!
Joshua022 is offline
Old 03-26-2012, 03:19 PM
Sounds good....
SS fan is offline
Old 03-29-2012, 01:13 AM
hhrumadbruh's Avatar
What amp are you going to run them on?
and how are you going to mount them?
I am going to get some components but was unsure how to mount them in the stock mount
I don't want to cut anything either
hhrumadbruh is offline
Old 03-29-2012, 07:11 AM
Joshua022's Avatar
Adapters to mount them.
Factory amp to power them. Putting an amp on speakers will only make them louder it doesnt change the sounds or add any mid/bass to them.
Im just wanting good clear sound not crazy loud.
They sound SOO much better!
Old 03-29-2012, 07:19 AM
chefhhr's Avatar
You know I'm pretty happy overall with the Pioneer system. I can't see putting any extra money into the stereo but I would love to change the headunit out to a DVD unit. That's probably going to be my next big purchase...maybe sometime over the summer.
chefhhr is offline
Old 03-29-2012, 07:52 AM
JAMIROBri's Avatar
I just did this. $80 for clearance Boston speakers front and rear and $25 for open box Sony tweeters and the sound is definitely better! Well worth the $105 upgrade!
Brian
JAMIROBri is offline
Old 03-29-2012, 07:54 AM
Joshua022's Avatar
Im throwing in some headrest dvd players for my kids this weekend!
Old 03-29-2012, 08:31 AM
chefhhr's Avatar
Let me know how this turns out. I'm thinking of adding at least one for my daughter...don't really need two although I know two looks better.
chefhhr is offline
Old 03-29-2012, 11:37 AM
hate to break it to you, but a high pass amp will make the speakers (tweeters ) clearer
They dont /make/ the speakers louder - that part is controlled by you and partly the gain on the amp.
The factory amp /might/ be good enough but i would ditch it.
I bet that factory amp barely does 20w rms and i doubt its got decent circuitry. Chevy isnt exactly a specialist in car audio
Also, try turning all the bass off from the bead unit. It makes the stock tweeters much clearer.
If you want bass, install a sub woofer or 6.5" woofers that have a frequency response of 20-30hz and up
The stock mids and most mid range drivers have a frequency response of 65hz and up usually.
Hope this helps.
Old 03-29-2012, 11:46 AM
Joshua022's Avatar
They seem to only come in pairs. Only wire that has to be run is the power and some manufacturers give you a ciggarette lighter adapter you can use instead of hard wiring it to your fuse box. All the FM modulating and head phones are wireless!
Quick Reply: New speakers/tweeters
