Oem radio question
Old 01-12-2015, 02:03 PM
pdmorris1's Avatar
Problem solved
I wasn't going to post on this form again because of DonBrews,Comments. I guess he has no exceptance of HHR owners that are not as knowledgeable as he. His arrogance is way beyond exceptable as far as I am concerned. But in trying to be of some help to others maybe having the same issue as me with intermittent power on my radio. I decided to replace my 2 year old battery. I am not sure why but my radio works fine now. The battery had been checked and showed fine. The car was starting every time but maybe there was a weak cell that was not keeping 12 volts on the battery when engine was not running. I am not an expert on this, but everything is fine now. Maybe mr do brews the know everything person has the answer
pdmorris1 is offline
Old 01-12-2015, 05:34 PM
Just my thought here. I would guess that by disconnecting the old battery, that the radio and/or the BCM went into "reboot" status.
This reboot(or restart) of the electrical system may have cleared up the radio problem allowing it to now work.
The radio could work for a long time, or start acting up again. Hard to say. Since you never were able to determine the exact cause it's just hard to be sure.
Fwiw. I seriously doubt the battery was the cause of your original problem. But, glad the radio is working for now. Hopefully it will not give you any more issues.
firemangeorge is offline
Old 01-12-2015, 05:39 PM
pdmorris1 - you might want to go and check your classified ad looking for a replacement radio. People have been leaving comments/suggestions/offers and you have not acknowledged them.
whopper is offline
Old 01-12-2015, 05:55 PM
He does not ignore advice.
And I don't know when I threatened his shoulder chip, I have re read my post 5 times.
I do have a lot of "exceptance", I think. I know everything I know "except" what I don't know; and that's a lot!.
donbrew is offline
thunder11
06-30-2012 02:39 PM
FargoFlash
07-12-2011 04:54 PM
HHR4JK
01-02-2009 11:11 PM
Smoke Wagon
03-19-2008 05:39 PM
DdAMaN21
09-25-2006 09:39 PM
Quick Reply: Oem radio question
