Pics of my Worlds LOUDEST HHR
You SPL guys are sick! Lol, both of your rides look insane. Just to give an idea of how hard it is to get higher and higher SPL's if memory serves me correctly you must "double" your power in order to get only a 3db gain! That's not to say that there aren't other ways to achieve higher SPL's but it is a rule of thumb in the SPL arena :) You guys are crazy though!
the rule of doubling the power or doubling the cone area for a 3 dB gain is a rule in theory and perfect conditions only.
In "real world" situations, you have many variables to contend with.
You have impedance rise of woofers, the impedance will change with more movement of the woofer and also change with the generation of heat. You have power compression in the box and the car's cabin. Power compression is when the woofers are moving to the point of compressing the air so much, its at the point where the woofer does not have the strength to compress it anymore, and more power to it just wont make it move anymore.
Then your electrical system has to keep up. By adding another amp, you also are drawing double the current, and you cant get more power out of the batteries than they can give.
My box has very low impedance rise (1 ohm nominal to 1.2 ohm) so with 1000 watts per sub to 2000 watts per sub, I have achieved a gain of 2.8 dB.
With 3000w per sub I start to experience power compression so I gain only 1.2 dB from 3000w per sub to 6000w per sub. So to keep it efficient, I only run 2000-3000 watts per sub at any given time.
I will retune the box to allow for the higher compression and this should give me a big gain at high power levels, but it will sound bad at lower levels.
My test box has yielded 158.1 dB with 3) 12s and 3000 watts per sub. This is not an official score in competition so I dont count this. My goal is to implement that box's design with my SQ box's design to get good sound, and high dB.
I know I am crazy and I love it, thank you.
You guys are awsome and I love all of your cars
Yeah I forgot about the double the cone area part! People don't realize that high DB is easy up to a point and then it becomes a real science. Perhaps you will be filling your HHR with concrete next? lol not that desperate I'll bet. I remember back in the early or mid 80's a guy with a VW bug with 2 15's and 1000 watts set a record somewhere close to 150. It was a big deal back then. I'm from Florida origionally and at the second anual Spring Break Nationals I sat in the Rockford Fosgate super van with 4000 watts and 8 18's (back then that was INSANE)! I don't know how loud it was but I couldn't even understand what I was listening to! I was cool to say the least but just never took with me. I've built some loud cars but never for myself and certainly not to the level of what you and that other dude are doing! Keep pushing the envelope and helping to progress the sport. It all seems to surround around DB comps now.
The RockFord van you have seen could have been 1 of 3. Mark Fakuda had one and Team X-Max had the other. I forget the other one. My buddy Jonathan Demuth helped build them all. They were at the top level with about 158 dB on the AudioControl. their 4000w rating was underrated. The amps were modified and it put out more like 20,000 watts. A couple years later they took out the 18s and put in 40) tens and got over the 160 dB mark.
We dont use much concrete anymore because its not strong enough, we use a fiberglass resin mixed with sand. It is much more dense than concrete. And yes, I do have some sparingly already in my HHR. I will use much more if I decide to build the wall but first I have a goal.
My old car was a walled plymouth Horizon with 2) 15s. my top score was 156.3 on the termlab in 2003. But the car weighed 5500 lbs and I kept breaking axles. So my new goal is to use my HHR with a street style box (no wall) and top that score. Once I do that, then maybe I will wall, just not sure yet. The batteries I have are 75 lbs ea, subs are 55 lbs each, and amps are 40 lbs each. I want to keep weight down to the point where I am not breaking the motor mounts, and transmission. I lowered the front 1.7 inches and left the back stock and it sits even now.
Thank you for the kind words and I am in no way trying to down Collyn, I am just trying to breed healthy competition and let people know what these cars are capable of. So far Collyn's install looks sweet and I cant wait to see it finished. I am also dying to see an actual official score posted from his install, I will be quite impressed if it does over a 150, but if it does, I will humbly step down as the worlds loudest HHR.
Most of the subs we use in SPL competition are much more suited to get loud than a PA driver. The key is motor force and linearity under extreme excursion. When hitting 170 dB, the pressure will build to the point of exerting 300 lbs on the cone of a 15" woofer. PA speakers will blow apart with that much force and the motors do not have enough horsepower to push the cone into that kind of pressure. Also, alot of us put over 20,000 watts into each sub and most PA speakers cant handle that.
Many of us have built horns but they must be very large to work correctly at low bass frequencies (which is what we play, rules limit it to below 80 hz) So a 20 hz wave is 56 ft long and the diameter of the horn opening must be equal to this. Also, the horn is designed for to project and the point of focus of the highest SPL from a horn is usually 1/4 of the wavelength away from the opening. Even at 60 hz, this will not fit into any car. so when people shrink or compromise the horn's design, it just doesnt work well. So we use ported boxes and/or band basses to use the rear and front wave of the drivers.
Here is a vid of the world loudest street driven vehicle. He can hit 170 on the termlab but keeps blowing windshields as he reaches mid 168s.
http://www.youtube.com/watch?v=EG7AUqsy3o4
HaHa i didnt know you guys were limited to 80hz and below. Whats that rule all about? Is it the cool factor or something? Probably some safety thing for human ears just in case I'll bet. On my old IASCA CD's the first one has a Jazz tune we used to play for SPL and then they changed to where there were 4 different songs, one Autosound2000 song and some technobeat bass stuff for the other 3. I've been out of it for a while though so I'm kind of like the dude at skatepark with the wide board and all the kids are riding the newer skinnier ones :) Thanks for taking the time to edumacate me back into the loop! Even though a lot has changed the basic principals are still the same so at least I'm not completely lost. I may have to print out the new IASCA rule book before I start tearing into my car to make sure I'm within the rules. I think I saw on thier site where I could download it but I'm not sure if they will want a membership? Thier site sux btw. Looks like a little kid designed it. lol Thanks again.
As far as my readings....they are real and accurate. It really doesn't matter to me though as I am not an "SPL" guy....I am one of the creative people that have rules changed away from us to suit the uncreative people. I am a past world champion....several times over. I do not really compete that much anymore. It isn't really fun to build a $30k-$40k system to the rules....only to have them changed when others get tired of loosing.
As far as trying to beat someone elses HHR? I will not really try. I will however park next to them and we will have the loudest HHR blockparty at a car show!
