Pioneer AVIC XX and HHr Question
I have an AVIC D3 that I am going install into my new SS. My question is this?
With the AVIC installed and you turn on your headlamps does it dim the AVIC display? I have an avalanche with it now and it does not dimm the screen and makes it very difficult to drive at night.
Thanks
JV
Thanks
JV
I'm not sure on that model avic, i have the avic z1 and the display doesn't automatically dim for me by the headlights being on or off. with that said i do have a small toggle switch (which was installed along with my head unit) that will switch the units display from day to night mode but that wasn't the switches primary purpose which is to bypass the units security feature of not displaying video while in motion.
Hmmmmm
Thanks
PS The D3 has a pin that you move from one position to another on the connector and it works while driving. avic411.com is a great resource and has the photos how to make it work
JV
Thanks
JV
or not at all... especialy if you dont have ABS , i have one in mine and the gps isnt off by more than a 30 feet at the most... you can also get the signal off the yellow wire on PCM but dont remember what conector it was.
Actually the wire harness kit I used, Axess, has a lead wire connected to it so it is part of the harness. You have to make sure that you get the NEWEST GMLANOS-04. There are two versions floating around.
