Placing a sub in the stock hole on an LS.
Old 03-17-2007 | 11:31 PM
Chris'sHHR's Avatar
Did I see someone on another post say that the factory radios have RCA output jacks?
Old 03-18-2007 | 09:58 AM
cyberone3's Avatar
no the factory radio doesn't
Old 03-18-2007 | 10:08 AM
HonestBlues's Avatar
I am thinking about adding one of these...I wonder how much of a problem it would be to wire it up to the factory system. http://www.pricegrabber.com/search_g...sterid=3106595
Old 03-18-2007 | 10:39 AM
captain howdy's Avatar
Easy.
Old 03-18-2007 | 10:57 AM
Easy.
Have you done it? And if you have,where do I connect the wires to hook it up?
Old 03-18-2007 | 11:38 AM
Do you have the system with the sub?
Old 03-18-2007 | 11:57 AM
Nope...base 6 speaker system...that's why I want to add a sub.HB
Old 03-18-2007 | 12:13 PM
You'll tap your rear speaker wires then. The power will tap off your battery like any other amp.
Old 03-18-2007 | 09:06 PM
cyberone3's Avatar
tap into rear speaker to a line converter or a sub crossover to you amp pretty easy
BlackknighT
"How To" Tutorial Library
06-16-2010 02:45 PM
Jeff®
01-15-2009 01:04 PM
tony326
12-12-2008 01:44 PM
SBHHR
War Stories
07-21-2006 08:29 PM
Quick Reply: Placing a sub in the stock hole on an LS.
