push button start
It's ironic that someone brought this up. I had been thinking about installing the Corvette system on my HHR. The parts are terribly expensive, however.
Lincoln, Lexus and some others use the same idea.
#26
I did it on my last showcar the company ignited gave them out to all the showcars at the show with a sticker to place on our windows that said
(push button start) you usually mount it in the cigerete lighter area looks great
but these are cheaper can be found on ebay $30 ish and the key has to be just put in the lock to work then push i like the lexus better! $$$
jeff
jeff
#28
Hello
My first car, a 10 year old 1950 Chevy had a push button start, a step up from the earlier foot floor start but you still had to turn on the key. My 1948 Pontiac had a floor start but I converted it to a push button. Easy in those days
When I first saw the ad I laughed and said that is not new. I guess not having to use a key at all is new.
I like the idea but wouldn't spend a lot of money to have it.
Boydie
Boydie
#29
I remember GM cars had an ignition that had two or 3 positions. Lock, start, and ACC. (I think). If you set the key in the start position and removed it, you could start the car without the key. I think these were used in the 1950s.
I put this ignition in my '65 Buick LeSabre and never needed the key.
Boydie
Boydie
