radio issues?
radio issues?
not sure if this is a repost, but we have been having some issues with the stock radio as of late. Sometimes, it will work fine, other times only some of the controls will work, other times non will work. any recalls yet?
It's nothing major if it does stop working. You're under warranty so just take it back to the dealer and they will put in a new one. I went throght 3 stock 6 disc stereos in my Mustang. Discs kept getting stuck in it while ejecting so I made them keep replacing it untill I got one that worked correctly. Thats what the warranty is for.
Originally Posted by Riggs
Has anyone else noticed the auto volume is a bit annoying and drastic in change. When you reduce your speed the sound seems to cut out all together. Has anyone else experienced this?
What I noticed with mine is that there is not enough volume and the fade between front and rear is not the greatest. I think a better set of speakers in the back would remedy this. As far as reception, it is far better than my wife's '02 Mustang. No problems with it cutting out or anything like that -- so far.
Might save you some money - as the head unit is "lacking power" in the rear speaker outputs.
Hope it helps,
